911/930 Megasquirt config data
I've recently completed a full rebuild on the 930 engine in my 911SC. Now that everything is working I'm having a blast. Here are the basic details on the rebuild:
- 1978 930 engine
- an Ollie's line-bored shuffle-pinned case
- twin-plugged, ported, polished & flowed heads
- full balancing
- 8:1 compression ratio
- 964 cams
- 3.2 Carrera intake
- 50# injectors
- K27-7200 turbo
- GoingSuperFast full-bay intercooler
- B&B headers
- dual 6 plug EDIS ignition
- 0280122001 Bosch throttle position sensor
- Megasquirt II v 3.0
Several of you asked that when I got a working Megasquirt configuration that I share. I'm still fine tuning, but here are some files that could be useful to those of you taking on a similar installation. Remember, these files work for my configuration. If you choose to use them and damage your engine, it is your responsibility. You should read the Megasquirt documentation closely and review all of the settings and tables for applicability to your application before proceeding.
I have placed copies of my config files on my server. The files include:
VE table (vex file)
Spark table (vex file)
AFR table (vex file)
Some sensor config information (Microsoft Word file)
Complete .msq starter file (Megasquirt II config file)
If you see something that needs correction let me know and I'll post a revised file. Enjoy!
Mike
- 1978 930 engine
- full balancing
- 964 cams
- 50# injectors
- K27-7200 turbo
- B&B headers
VE table (vex file)
Mike
