Starter mystery...
I used crimp-on AMP ring terminals at both ends, sized for the wire and starter lug at rear; at the battery end I used a ring terminal sized for a new battery terminal clamp, the type that lets you bolt two sets of ring terminals (one large, one small) on to it (see pics).
You do need to have a suitably beefy crimping tool, solder gun and heat gun - see pics... the large hand crimper would do, but I have the Harbor Freight hand-held hydraulic crimper/swager with dies that is easier to use and works much better. 150W solder guns work well to allow thorough soldering of the crimped terminals. I used marine-grade heat shrink (also from HF if you don't have the really HD stuff) over the lugs and wire ends for reinforcement and protection, the type that has adhesive/sealant inside.
Really important to clean the fresh ends to maximize conductivity and make it easy for the solder to wet everything inside the voids in the crimp. You can tease out the strands and clean them using heavy tweezers with the copper braid from a piece of coax slipped over the ends. Don't use acid cored flux! I used high-silver content flux-cored solder (Radio Shack, Fry's etc) which is (unnecessarily so in this case as I crimped first) also mechanically stronger than regular electronics solder. Main thing is not to let the inevitable excess molten solder fall on you when soldering the starter lug!
Good luck!
Team Owner
Thats some nice work right there . The key is the crimping for sure. I see what you did with all the extra bolt on's too. I was wondering what to do with all those extra wires.
Also I noticed that the pic shows a solder cup lug, not a crimp lug, on the battery end. It was just what I had in my tool box. Crimp then solder way to go, for sure - to get a good joint with the large solder-cup lugs is something helped by prior experience ...
You are right about the marine battery stuff. I've got some pretty serious Group 27 batteries in parallel on the new boat for the house power. Two battery switching systems, charger, etc. All mounted to threaded posts. Nice.
