my rear shocks are a bit more worn than the front..is it ok to do just the rear?i will be replacing them with the original,so they will be the same..i plan to do the fronts in a few months...thanks,j
I agree with Eric. Unless you know that a previous owner, or you, have already done the fronts and that the rears are significantly older, do the entire set.
Pete
