flasher relay 82 SC
Do any of you know the part number/description
for this relay tucked behind the fuel gauge
it stops working sometimes and only goes with a tap,
So I expect its likely, thisrelay is at fault
(PS can't find any refference, to the printed # on part)
Pelican parts list a part without similar number for sale
with a small picture
not very good for comparison, and a google of the
part number on mine, doesn't help much
apart from taking the component of the car and into a porsche centre
where else might I order one?
had the actually relay out, and popped plastic cover off, sprayed it liberally with switch cleaner
and replaced it,
but still the same,
seems to go with a little wiggle,
the socket it plugs into, is not fixed behind dash board, just hangs behind fuel gauge, perhaps the prob may be a dodgy connection there instead
perhaps
and replaced it,
but still the same,
perhaps
