911 Forum 1964-1989
88 Cabrio power top problems
Old Jun 19, 2003 | 05:50 PM
S4Vols's Avatar
S4Vols
6th Gear
Post 88 Cabrio power top problems
When I open the power top, the passenger side lockdown motor runs and the driver side lockdown motor will not run until the other one is finished, same problem when closing the top. I replaced the power top switch thinking that the switch couldn't handle the current load, but the problem was not fixed. Any suggestions?
Old Jun 20, 2003 | 12:33 AM
Lorenfb's Avatar
Lorenfb
Post
You may have a problem in the cab top control unit
or the switches in one of the locking motors.
The cab top system is very problematic & difficult
to trouble-shoot.
Good luck
Lorenfb@systemsc.com
Old Jun 20, 2003 | 01:55 AM
LoudC4's Avatar
LoudC4
Post
I have had that problem and more. Solution - replace the control module with one from a 993. You'll need an adaptor (avaialable from P-dealers) and then you can simply pull over, pull on the handbrake and operate your top with the engine running - thats right no more turning off the engine and draining the battery first.
This is a recommended upgrade from Porsche as the old control modules are NLA I've been told.
Cheers
Mark
Old Jun 20, 2003 | 12:57 PM
Lorenfb's Avatar
Lorenfb
Post
They fail just like the 964 ones. Plus, you need
to "pull" a new wire to the updated unit.
Don't replace the unit until it really needs
replacement. Don't waste money.
Good luck
Old Jun 20, 2003 | 01:00 PM
Lorenfb's Avatar
Lorenfb
Post
Correction! If you don't have a 964, you may
have to "pull" two wires, i.e. the oil pressure
switch and the handle brake switch.
Good luck
Loren
Old Jun 20, 2003 | 03:36 PM
S4Vols's Avatar
S4Vols
6th Gear
Post
Thanks for the input, It's up for sale right now and I'll let the potential new owner know the solution to the problem.
Old Jun 21, 2003 | 07:28 AM
LoudC4's Avatar
LoudC4
Post
</font><blockquote><font size="1" face="Verdana,Tahoma,Helvetica">quote:</font><hr /><font size="2" face="Verdana,Tahoma,Helvetica">Originally posted by Lorenfb:
<strong>They fail just like the 964 ones. Plus, you need
Good luck
Lorenfb@systemsc.com</strong></font><hr /></blockquote><font size="2" face="Verdana,Tahoma,Helvetica">Fair enough. I decided to put a secondhand control module from the 964 into my 87 today. A few wires and 15 minutes later voila, no more problems with opening and closing and I can keep the engine running!
OH yeah... and it cost me all of US$125 which for this fix was pretty acceptable IMO.
