Speedo removal advice needed
Dear All,
I'm trying to remove my speedo to get the odometer fixed. There's three round red plugs that go into the rear that feel like they are attached to springs when I tug them.
Is there a specific way to remove these red plugs, or can I just yank them out??
There don't seem to be any removable clips holding them in, so I figured I'd better seek your collective expertise first. Please help.
Thanks in advance
Puf
Thanks in advance
Puf
it is the bulbs. you need a special tool to take the outer ring of with the glass in order to get into the speedo. you then have some screws at the back that will seperate the speedo from the housing..
Hi guys, Pull the speedo out of the dash , point the guage face down. This gives a good visual to see the wires for the bulbs. There's a lip around the wire holder you pry up on to get the bulb out . Small flat screw driver works best. Don't pull on the wires. Easy fix you'll see, good luck.
Mducharme (Mike)
Mducharme (Mike)
