is this engine rebuild expensive
rebuild 3.2 Carrera engine. 1987
Rebuild engine
Replace. all seals, bearings, gaskets, piston rings, valve guides, timing chain & guides, teflon guide seals, O rings, rod bolts, copper heads rings, cylinder shims,
crush washers, 6mm & 8mm nylon case nuts. oil & air filter, spark plugs Engine oil.
Rebuild heads, replace guides, competition cut valve seats & valves / cut stage 1 porting.
check cylinders, de-glaze hone
Balance crank rods & pistons
Re condition rods
Check line bore of case
Assuming that the cylinders are usable, and that their is no engine component damage
Total cost ........................................................................ ........... £2900.00
I year / 12000 mile warranty
Options
964 cams, competition valve springs w/ retainers & locks.................£ 475.00
Big bore 3.4 cylinder piston kit, from ..............................................£2200.00
High flow exhaust system options
other items like Clutch, CV boots / joints
seized bolts, corroded / damaged / worn parts etc may need replacement or repair
at additional cost
does this cost of rebuild sound expensive and the work that is to be done is it normal for a rebuild or is there extra work in this quotation any ideas what gains in power would be seen with such a arebuild
Rebuild engine
Re condition rods
Options
at additional cost
My engine rebuild for a 3.0 SC motor cost much more.
RL Technical Advisor
That looks VERY reasonable to me, given the parts list. I've no idea what their labor rates are.
If you have to buy valves and P/C's, the price will certainly go up,....
Jaws:
Labor rates vary all over the country and thats the biggest factor in a top-end rebuild.
I'd budget in the $4.5-$6K range for parts, labor, & machine work.
Here in NZ, it cost me just on NZD$10,000 for a full top end refresh (re-used original p&c) and new clutch (G50).
This equals appx US$7,000.00.
Labour rate was $60.00 per hour with appx 60 hours....
1 Post
Are NZ hours shorter than the rest of the world???? 60 hours for a top end rebuild............your engine, trans, engine bay better come back spotless for that......................The last motor I did was a 930 complete, with all the mods, detailing the engine comp. and all the hardware, and I charged 65 hours.
fixnprsh, yes the engine and tranny was smick after the rebuild but engine bay was left untouched.
The guys did say the clutch took longer than it should have due to a stuck bearing, I think it was......
