Any differences b/w 3.2 liter 84-86 & 87-89 Carrera
Originally Posted by JCP911S
The whole chip debate is like discussing religion....
Flame away if you must, Loren, but please provide some hard proof to back up your position.
Continuing with your FWIW, I've posted about this on this site before. I have my 73 911. Over the years I kept trying the new 911s - 75, 78, 80 and 84. With each one, I came away feeling that even if they were faster, turned quicker and stopped shorter, they didn't feel better than my 73. They felt heavier, less sporty, less responsive, more numb. So, after the '84 Carrera, I just stopped trying them. Just this year, I was helping a friend sell her '87 and I took it for a 30 minute spin to warm it up for a prospective buyer. That car was fantastic. I found it had all the spice and sportiness I found lacking in the earlier cars. In fact, if I had known how much I'd like it before buying my Boxster S a couple years ago, I'm pretty sure I would have bought an 87-89 instead. I commented about my discovery on this board and had some of the same folks above mention the dispute over the chips and other minor things.
So, I don't care what the truth is about the chips or posted hp. I don't care if that extra sportiness was because of more hp, or quicker advance curve, or some undiscovered fluke in the production line, or whatever. All I know is that it is there and it was enough to make a big difference in driving satisfaction to me.
Originally Posted by randywebb
Peter - do the chips have p/n's on them -- or any other codes that differ and might explain the differences you found?
"357" chip (357 is the last 3 digits of the part number.) Standard in late Carreras through I think early to mid 88 production?
"358" - difference from 357 is chip is primarily in the full throttle maps, with everything else pretty much the same. The 358 chip injects about 2-3% more fuel above 6000 rpm, and the ignition timing is about 4-5 degrees more advanced from about 1000 rpm up. Rev limit is 6580 RPM. I think the 358 chip was standard in about 40-50% of the '88 and all of the '89 US Carreras.
"330" - Club Sport chip, same as 358 with revised rev limit of 6840 RPM.
"but they had to map the chip for a 'lowest common denominator' in terms of quality of gas,"
That's not totally correct, as the 3.2 DME has a jumper (pin 10) which when grounded
retarded the ignition. So, basically the ignition timing was not set for the worst case
but for the nominal (average) octanes at the time. This is basically how most products
are designed for, i.e. the nominal market characteristics. Then for the worst case octane,
the jumper is used. Furthermore, the octane levels now are for the most part
effectively worse than the '80s.
Bottom line: We all need to agree to disagree and move on,
since we all made our points!
Thanks for the breakdown of the chip differences, Dave. Interesting. I haven't poked inside my DME yet. My 'brain' - no smart comments now - as the PO (a nice lady & very honest) called it was replaced 4 yrs ago - no invoice however. It will be interesting to take a look & see what I have.
Ian
Ian
Ian
Ian
Loren, I concur: We'll all need to 'agree to disagree' and move on...everyone should do their own research (there is plenty of info in the archives on both of these boards) and make their own informed decisions. Although we 'disagree' on Steve W's chip, I do thank you for raising everyone's awareness about the potential issues at hand...I know I'm better informed due to your posts.
Keith
'88 CE coupe
Originally Posted by KC911
Ian, if I were you, I'd take a look asap and see what you have installed.
I went back into the records & I did have a bill. The PO spent $1150 on a new 'computer', $138 on a 'ref sensor' (O2 sensor maybe?) & $42 on 'comp. relay' (DME relay) in Aug 2003 - a year before I bought it. She was not a car person & the Poorsh was just her winter condo car since 2001 - Florida y'know - with only 3K miles over 5 years.
I'll find out what is in there & figure it from there. With the hysteria of the chip or not to chip debate & an all stock car, I'm in no rush.
Ian
Ian
Ian
Keith
Oh, I found the rev limiter one day in second gear . . . it works & seems to be about where it should be . . .
Ian
Ian
