oil temp sensor in oil cooler for 87 911
does anyone know the part # for the oil temp sensor in the oil cooler on an 87 911? the one that mounts in the remote oil radiator
that is normally mounted in the right front of an 87 911 3.2. this is the oce that turns on the fan. or better yet the bosch # for one that turns on at a lower temp.
thanks keith
87-slant nose cab
thanks keith
87-slant nose cab
Keith, the part number for the original temperature switch is 930.606.118.00 per the Parts and Technical Reference Catalog.
Unfortunately, I don't know a Bosch number but I am thinking that I would also like to replace mine with one that turns on at a lower temp. And I would rather not install a manual switch so that I can preserve the car's originality for now. Hope someone has an answer!
I'll quote the pelican board's guru Warren Hall:
My feeling is that the factory 'fan kit' is a bit overpriced and that the thermal switch in the kit is wrong for protecting the engine! The fact that there is a shroud that fits is good, but Bruce Anderson has said that the switch doesn't come on until about 257 degrees F, a figure far too high ... in my opinion! I would prefer a 200-210 degree range, and a dashboard swtich would be an easy way to override the oversight, but there are switches for 924/944 fans that are available in four different settings from 71 degrees C thru 92 degrees C ... in the Automotion catalog. Any of those switches would be preferable to the factory 125 degree C switch!
JACK,
YES THEY ARE IN TWEEKS TOO BUT WILL THEY FIT IN THE OIL TEMP SENSOR HOLE IN THE OIL COOLER? I DON,T SEE WHY A TEMP SENSOR FOR
THE RADIATOR WOULDN,T WORK FOR OIL!!
THANKS KEITH
THANKS KEITH
GUYS, IT SEEMS ALL OF USE 911 OWNERS ARE LOOKING FOR A LOWER TEMPERATURE FAN SENSOR.
I JUST FOUND BOSCH,S WEB SITE AN E-MAILED A REQUEST FOR INFO ON THE TEMP SENSOR (I HOPE
THEY MADE IT FOR PORSCHE AND PORSCHE JUST
ADDED THERE PART #930.606.118.00) ANYWAY IF I GET A RESPONSE FROM BOSCH I WILL LIST IT
EXCEPT FOR THE BOSCH # WHICH I WILL THEN OFFER TO THE 911 WORLD AT HANDSOM MARGIN
(GOTTA PAY FOR THIS PUPPY SOMEHOW).
JUST KIDDING BUT IF ANYONE HAS A NEW ONE
THAT CAME IN A BOSCH BOX PLEASE SEND ME THE BOSCH # SO I CAN START TRYING TO FIND ONE THAT ACTIVATES AT A LOWER TEMP.
THANKS
KEITH
THANKS
KEITH
Guys,
It is easy to wire in a switch to fool the relay into starting the fan. I used a rear wiper switch in an unused hole under the lip of the dash just below the gages. You can feel the cutout in the tin for the switch through the vinyl.
I fire up the fan when the needle goes 1/4 above the lower white mark. There are many ways to be happy.
Ned Monaghan
Ned Monaghan
ned,
just got a reply on pelicans board about
avaiable switchs from pelican. part#
61-31-1-364-273 for a 99c switch and #
61-31-364-27291 for a 91c switch both at
$18.50 each.they even have pictures, the
only thing i,m trying to figure out is the lower temp switchs have two contacts instead of one but i,ve already e-mailed pelican for wiring instructions and as soon as they send that i,m going to order one or both. thanks to everone for the posts i hope we,ve found the answer.
keith
keith
