calipers upgrade
Basic Sponsor
calipers upgrade
Hi guys what do I need to upgrade a 1977 911S with Koni struts 3.5 bolt spacing, with the calipers from a 1986 944 Turbo.
Sorry for the noob question.
TIA
LART.
TIA
LART.
Calipers need machining to reduce the bolt hole centres from 3.75" too 3.5"
New mounting bolts,
New pads,
Brake lines, I used braided & teflon coated lines from Pelican, but make your own decision on line material.
New rotors are advisable. The 951's allow a wider rotor so might as well use it. Think mine came from a 80's carrera.
Err thats about it. Just go & bolt the lot on
New mounting bolts,
New pads,
Basic Sponsor
New mounting bolts,
New pads,
New mounting bolts,
New pads,
Many many thanks..
