rubber oil line size
Does anyone know the inner diameter of the rubber oil line that runs from the engine case solid line (that goes from the left side of the engine case around the back end of the car to the right side) and connects up to the front oil cooler loop line at the top of the right rear wheel well? Mine is showing some chaffing, so I want to replace just the hose portion rather than buy the whole hose/tube assembly. Yes, I could cut it off and measure, but since I'm sure that I'll have to order it, I'd rather keep the car on the road until I have it in hand. thanks
Frank
88 951
80 911SC
71 914
Frank
88 951
80 911SC
71 914
