84 carrera revs up and down, sometimes stops
Hi all,
I've had this car for about 6 mths and maybe 3 or 4 times , when still cold, the engine has stopeed as I've come to a stop in neutral.
Also, only twice, when I've started the engine while still warm (stopped for maybe 10 mins), it has revved up and down between about 600 and 1500rpm with no pressure on the accelerator. The first time a guy up the road fixed it by putting his hand on the engine (true) and the next time I just turned the emotor off and restarted.
Any suggestions/ideas?
pete
pete
There are lots of threads on idle surging. I had a similar problem. I replaced lots of parts before someone suggested I get the mixture adjusted. Problem solved!
