911 Forum 1964-1989
Shifting problems 911 sc
Old Jun 8, 2005 | 08:52 AM
Wayne Williams's Avatar
Wayne Williams
Default Shifting problems 911 sc
Guys its me again!!!,
I am starting to have problems shifting gear on my SC - it has a recon 'box, new clutch and a short shift kit fitted.
In the last few days, it has had problems getting into gear - no baulking/grinding but it feels like the linkage/rod is misaligned or loose.
Yesterday, I had problems with 2nd and 4th - within 10 minutes it was fine - I thought it could be cold oil and thought no more of it.
Today, 1st, 2nd, 3rd and 4th are fine but I am having problems with 5th!!
It feels like the Neutral plane is at fault because I had to slam the stick quite hard to get the shifter over to the 5th/reverse plane.
Any ideas on what I can check/adjust??
Old Jun 8, 2005 | 10:50 AM
Drew Theodore's Avatar
Drew Theodore
Pull the plate covering the coupler, on the coupler there is a allen screw that sometimes gets loose and causes inconsistancies in shifting. You can usually tell if that is the problem by putting the car in 1st gear and see if there is more than usual play.
Old Jun 8, 2005 | 11:24 AM
classic911's Avatar
classic911
Default Same problem here
so I'm attacking it with new bushings, Seine systems "gated" shifter (Father's Day Present!!) and fresh Swepco.
I'm getting third gear instead of first at stop signs, red lights, etc.
Very frustrating.
Old Jun 8, 2005 | 11:29 AM
Wayne Williams
Thanks Drew,
I will have a look when I get home tonight.
Its certainly not synchro rings etc. as the car normally shifts very smoothly.
Old Jun 8, 2005 | 12:12 PM
Peter Zimmermann's Avatar
Peter Zimmermann
Wayne: The allen screw that Drew mentioned is a good thing to check, although they don't normally come loose. But you'll be in the right area, because it sounds like your coupler bushings are failing/have failed.
Pete
Old Jun 8, 2005 | 05:24 PM
Wayne Williams
Thanks everybody,
Drove the car home from work tonight with no issues at all - I even drove a different way home which avoids motorways (freeways to our american friends!!!) to ensure more gear shifts - no issues at all!!! I'm sure this Porsche is testing my patience!! or is it letting me know who is the boss??!!!
Pete and Drew, Thanks for your input - I have checked the screw and it was tight so if the problem returns tomorrow, I will order some new bushings and replace at the weekend.
Once again Thanks
Old Jun 8, 2005 | 05:39 PM
Drew Theodore
Wayne, one thing I notice in my car is that it shifts better when the engine is warmed up, but not hot. I dont know if the motor/transmission mounts get softer when the motor is hot and lets things move around a little more. The last time I adjusted my coupler, I had everything real hot and now it seems to shift a little better when hot.
Old Jun 9, 2005 | 10:36 AM
spydr32000's Avatar
spydr32000
Wayne, remove the gear lever and check the bushes on the shift rod support bracket, also the cup on the base of the lever, at the front of the sift rod near the support bracket there is another grub screw. This is also worth checking as I have found them to have come loose!
Regards Mike
