Varioram won't idle......
This has been a 2 month nightmare. 97 OBD II Vram runs very strong but will not idle when coming to a stop...
But the car restarts immediately!!!!! Anyone else go through this???
I'm running a remapped FVD DME with cyntex chip. Have replaced DME, ISV and DME harness to no avail.
I'm also looking for a source for a 993 OBD II diagnostic port to install into my system
Vram,
Won't idle? Does the car die immediately or does the idle hunt-before-death?
Quite a common problem on 964/993. Could be sucking air below butterfly? Check here first.
Often the mass-flow unit is guilty - difficult to check without correct equipment.
Another problem is the flywheel setup. Often a very light setup here causes the EMS to struggle to keep up due to the inherent loss of momentum - however your (unknown to me) EMS should be able to be programmed to fix this problem.
Give us a little more detail on your setup.
Tom
Tom
Thanks Cookie....I just dropped a diagnostic port off at the Bosch place so he could add it in and put it through his software...this is an 82 SC with a 3.6 and therefore had no port.....I'll keep this thread updated for future users....
