Getting the *@%^#%$ shift knob off?
That's a thought I had as well. Just worried about cracking it because the threaded opening leaves a very narrow wall thickness. I should be able to do that but want to exhaust the option to actually thread it on before I do. Check out the pics. I know it's not brand new but it just has this nostalgic look and feel to it.
Oh by the way the bentley manual I just got said one way to remove the **** is to use a 15mm open end wrench placed under the **** and tapping up from below. It's in section 340 pg 4 manual trans section.
Perhaps the german fellow who put mine on was in the dog house with the wife and was taking out his aggressions at work....
Originally Posted by 82Targa
Tap it with what? A 12 pound sledge hammer? I had a wrench perfectly fit on the shaft, everything was taped up to protect it and I was pounding on it hard. I tapped, I tickled, I thunked...no dice. The plastic of the **** started to give way with no effect on the crimp ring.
Specifically, with the shift assembly on the bench, turned it over, lined up a punch directly on the surface of the bottom of the **** next to the shaft, and then hammered until it came off/fell apart.
You might have a better chance with the shift assembly out of the car. You could turn it upside down and at least have gravity on your side.
I know things don't come off the way they're supposed to all the time. I could feel your frustration when you described the ordeal. I'd of done the same if the prescribed method didn't work...and with a vengeance..." allright you son%^$@# think you gonna beat me, take that you piece o%^^%5.." How much time is wasted on what should have been simple things. Enjoy the ****!
I'm pretty handy with metal fab, welding and the like, only thing I don't have is a lathe which would come in handy. I'm going to try fabing something myself and if it's a no go I'll try a shop. You're right can't cost much. I'm still thinking about Dan Cobb's post on drilling it out only instead of set screws maybe I'll get it just right as a press fit. I wonder what the **** came out of. Heavy SOB and the metal is shiny and odd, almost like a pot metal like material. I'll try to ID it and post my findings. Thanks for the compliments Randy and 82.
