911 Forum 1964-1989
Spacer on Chain Tensioner Upgrade?
Old 05-14-2002, 03:30 PM
Bob Springer
Bob Springer's Avatar
Question Spacer on Chain Tensioner Upgrade?
I am putting the chain tensioners back on and am wondering whether it is normal to have this much space between the tensioner and the sprocket arm? Does this seem right? I checked on Pelican and apparently you only need a spacer for the earlier models (77 and older), but this doesn't look right to me.
Old 05-14-2002, 05:44 PM
Bill Gregory
Technical Specialist
Lifetime Member
Bill Gregory's Avatar
Post
According to Porsche, 1980 and earlier engines need a two spacers, number 930.105.513.00. They goes where you're arrows are. Documented in Technical Bulletin 2 in the Parts and Technical Reference Catalog for 911's (catalog is part number PNA 000 147).
Old 05-14-2002, 08:15 PM
911pcars
911pcars's Avatar
Post
It's generally recommended to use the late idler arms ('80 up). They have a wider bushing that will take up the space. The "interim" spacers you got with the tensioner kit are priced right, but B. Anderson thinks one reason the early tensioners failed was because the early, narrow bushed arm would bind. The late arms are fairly plentiful on the used market (two for every basket case engine).
Sherwood Lee
<a href="http://members.rennlist.org/911pcars" target="_blank">http://members.rennlist.org/911pcars</a>
<a href="http://www.seinesystems" target="_blank">www.seinesystems</a>
Old 05-15-2002, 09:00 AM
bds1
bds1's Avatar
Post
I just did a post about this a few days back. I did the carrera tensioner upgrade on my 80 SC. After upgrade I have a nasty mystery noise after warm up. I measured the space that you show on my setup, it was about 100 mils. Lookslike you have ??? 250 or more mils. I ordered the spacers so in a few days I can measure them for you. But judging from your gap, I don't think that the spacers I'm getting will work for me!
Old 05-15-2002, 10:25 AM
Bob Springer
Post
bds1 - I saw your post the other day, that's kind of what motivated me to check into this. I knew it didn't seem correct to have this amount of space in there. You're probably okay with your one spacer if the space on mine requires two.
Does anybody have a set of the later style tensioner arms that Sherwood is referring to? Sounds like that's the best option.
Quick Reply: Spacer on Chain Tensioner Upgrade?
