Engine shroud replacemant
Technical Specialist
Lifetime Member
Lifetime Member
You may want to do a partial engine drop to gain better access to the top of the engine. The partial drop how-to is on the tech.rennlist.com under 911 engines.There's also an article about replacing the CIS airbox, which effectively clears away the top of the shroud.
