After the loving?....(lowering.)
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
Can I drive my 911 after adjusting the front torsion bar to measure a correct setting,2 to 3 days,or do you recommend an alignment straight away? Mike. <img src="confused.gif" border="0">
Technical Specialist
Lifetime Member
Lifetime Member
Mike,
If you're asking if you can drive your 911 after adjusting the front torsion bars for height, the answer is yes. If you were just fine tuning your height, you probably didn't change the geometry enough to require a realignment. More important when lowering is to have it corner balanced, which fine tunes the weights at each corner, and improves the handling at speed.
