VIN matches engine S/N?
The other day I wondered if the engine was original to my 911 1974 project. I was able to find the engine serial number last night. The VIN is 9114110070 and the engine s/n is 6151993. I understand that the 5 in the engine s/n means 1975 and the 4 in the VIN as 1974. With these two dates, could there be a senario where they actaully do go together? I had read that the engine s/n means 'last year of that model'. So could the '74 engine be made through '75 (if that makes sense)? I think the '75 engine has the oxygen sensor?, but I know mine does not.
Your chassis number indicates a 'G' Series August '73 to July '74 build Targa (not a USA car?) and is early in the series therefore likely to be a '73 build.
Your engine number suggests it is from a 'H' Series August '74 to July '75 Coupe (again not a USA car?). The number is late in the series and is therefore likely to be a '75 engine.
PJC
PJC
Lifetime Member
Lifetime Member
TT
The car is ROW (not u.s.) but now I'm un-sure about the engine. Where do I find the type number? I think the 645 indicates a '75 911S whereas the 615 would indicate a standard '75 911. I had expected to find a 614#. Thanks for your input.
It's resaonably clear to me - your quoted engine number is 6151993 which falls between 6150001 & 6152007. This makes it an engine from a rest of world coupe fitted with the 911/41 engine (or 911/46 for Sporto but as you don't mention Sporto I stick with the ...41 engine) - see pages 48 & 49 of the Porsche 911 Red Book by Paternie.
Tom, I think you may be wrong - are you assuming the engine comes from a USA car? I don't believe it does - it comes from a Rest of World - numbers begin 6150001.
PJC
PJC
Lifetime Member
Lifetime Member
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
74er- The type number is to the right of the serial number, stamped on a horizontal surface of the case behind the fan. It is near the righthand arrow in the pic below, with the left arrow pointing at the serial #.
TT
Lifetime Member
Lifetime Member
Tom,
Could you put up an image of your '67 S? Has it been your car for all that time or a 'family pet'?
![](http://members.rennlist.com/tweedt/67rear.jpg)
TT
Tom,
Fantastic story, lovely car. It's great to hear that at least one early 911 is driven and loved all within one family. Thank you for sharing the information and for the images.
Peter JC
Peter JC
