911 "M" caliper brake pads
Hi,
Just wanted to get some opinions on "M" brake pads. I see that Pelican offers various manufacturer's along with their opinion. I am only planning on using the car for street use. Any suggestions?
I use "Jurid" pads intended for Carrera rears. They have a cutout for a wear sensor - that doesn't matter. If you're not going to surface/replace the rotors put a small (3mm) bevel along the long edges of the friction material. The pads will be nice & quiet as long as you wash them with a direct stream of water (you will see lots of black brake residue under the car) through the spaces between the spokes of your alloys. Always wash them cold, always drive the car at least two miles after washing.
Pete
Pete
