Creaky Front Suspension
Question for all you suspension experts, I have owned my 1981SC since May of 2003 the PO installed turbo tierods and urethane bushings which he says makes the front end creak. But it seems to be getting worse. Is there anything that will creak or squeak from being worn down?
Thank you
Barclay
1981SC
Thank you
Barclay
1981SC
The Hoffinator
urethane bushings suck... they do squeek like a bitch and are quite harsh.
if its bushings and not anything else get elephant racing bushings, as they are good stuff,.
http://elephantracing.com/
It's really a shame when I hear about your situation. Non-rubber bushings are a horrible item to put on a street-driven car. They are extremely noisy at low speeds, to the point that friends might want to ask you when you're going to junk your car. The creaks can be alleviated somewhat by using a high quality amber grease (available at Pep Boys, etc.) but that is a lot of work, and won't last long. By your note, if your tech put plastic bushings on your sway bar only, they are not bad to replace (you have to loosen one control arm to do the job), and replacement rubber bushings are available from Porsche. If you have to replace the control arm bushings, find a really good suspension technician that can do the whole job, including alignment. Sorry it happened!
Peter - re non-rubber bushings on a street car
Do your comment extend to the Elephant Racing bushings? I think they are called poly-bronze, and are said to eliminat eeh problems of the poly bushings that most have used up until recently.
Randy - I do not know of anyone who is using the bushings you mention, nor have I driven a car with them installed. Sorry, but I can't answer that one...
Keith
edited...Oops, I see other responses before I saved my reply...as Randy said, check the threads on Pelican...I don't recall seeing anyone who wasn't pleased with the poly-bronze solution.
I had urethane bushings on my 71 and 84. I drilled thru the housing and bushing on my 71 and put in my own grease zurk (sp?). The grease will wear off eventually (quicker if it rains) and it was a pain to take apart and re-grease. The grease fitting worked well and made it simple to re-grease. On my 84, I used a hacksaw and cut several small longitudinal grooves on the inside of the bushings. You can then spray synthetic lubricant onto the bushing and it will work itself in. I had both cars with urethan bushing for 8 years, and either method worked fine with re-greasing/lubricating required about twice a year - or after driving in heavy rain.
I put in poly bushings with grooves and grease zerks (sp) and they are still unbearable. My son says "Dad you need to put a sign on your car that says "Fast cars squeek" 'cause your car sounds like a peice of junk!!"
