911 Forum 1964-1989
Modified airbox. 3.2 litre
Old Oct 10, 2004 | 10:12 PM
klgagnon's Avatar
klgagnon
4th Gear
Thumbs up Modified airbox. 3.2 litre
Hello everyone,
This is my first post. I just bought my first Porsche (86 Turbo-Look Coupe).
If I modify my airbox (by drilling holes or just cutting it out). This changes the air/fuel mixture right. So does this mean since more air is being sucked in, more fuel has to be pumped in as well. Does anything happen to the economy and or does the car begin to run rich or lean?
Old Oct 10, 2004 | 10:42 PM
Mongo's Avatar
Mongo
Official Bay Area Patriot
Fuse 24 Assassin
I haven't heard of people really "drilling" their airboxes on their 3.2 911s. Fabspeed sells cup airboxes for 3.2L motors also and thats pretty much the closest you can get to opening up the air box on it. I have never really heard of any gains. But I have heard good and bad things about cone filters for the 3.2L 911. Good luck and welcome to the board
Old Oct 11, 2004 | 01:23 AM
fixnprsh's Avatar
fixnprsh
yes, cone filters are bad. They do away with the velocity horn thats mounted on the ait meter and makes the air more turbulent.
Cut out all of your air box cover except for enough of a frame to hold the drop in K&N in place and you will pick up a few HP (i think its like 8hp). the only reason they never did this from the factory is obiviously the noise that it (should) make.
Old Oct 11, 2004 | 05:04 AM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Good advice about modifying the stock OEM airbox cover,....the cone filters will reduce HP.
I'd just say that the gains are in the 3-5 HP range.
Old Oct 11, 2004 | 10:50 AM
jet911's Avatar
jet911
You can also drill five or six 1 to 1 - 1/4 inch holes using a hole saw in the cover. Actually Steve Weiner has suggested this in the past. I did the mod, it sounds cool during acceleration, not much additional noise when cruising and not much if any noticable HP increase...
Old Oct 11, 2004 | 09:31 PM
klgagnon's Avatar
klgagnon
4th Gear
Hey Guys,
Thanks for the advice. I will try the drilling method and hope it sounds good.
But what does this do to the air/fuel mixture and does this effect anything in
engine performance in a negative manner?
Old Oct 11, 2004 | 10:13 PM
r911's Avatar
r911
Anti-Cupholder League
The computer is smart enough to take care of that.
Old Oct 11, 2004 | 10:36 PM
jet911's Avatar
jet911
Yep as Randy said, the computer takes care of it. I did nothing to the mixture...
Old Oct 12, 2004 | 02:03 AM
ProtoCab's Avatar
ProtoCab
You have a good base platform for a bolt-on turbosystem, so make use of those winder fenders and 930 brakes
Old Oct 12, 2004 | 05:33 PM
imcarthur's Avatar
imcarthur
Is there really any gain with stock exhaust etc? Or is it just louder?
Ian
Old Oct 12, 2004 | 07:07 PM
Hi Ian:
Here's my "political" answer":........It Depends,....
Assuming you are asking about exhaust modifications, there are some modest gains to be found by installing a good high quality sport muffler such as the Monty Muffler in place of the OEM one. I do not advocate removing the catalytic converter unless its plugged up; Test pipes make more noise than power (unless the cat is plugged).
You can however, make a substantial improvement (where legal) if you install a set of SSI's and a dual-inlet Monty Sport muffler. Thats no BS.
