Plug wire Broken?
While replacing the cap/rotor on my '86 the other night, I may have damaged a plug wire.
While wrestling the wires off of the old cap, I noticed that I had a wire disconnected from the connector. Not having another handy alternative, I just shoved the frayed end back into the connector.
After work complete, the engine ran great, with no signs of a "miss".
Considering all I've heard about old wires degrading,high performance wires etc, I can't believe that the wires work this way. Was "Murphy" looking the other way on this one?(a first for me). Will this act up later?.
I'm probably due for a new set of leads but don't awant to buy right now.
Inputs appreciated as always.
On my 3.0, there is a threaded "screw" like feature on the end of the connector where the wire goes into it. When mine came off, I snipped off the end of the wire to expose a nice cross section with a tight center wire core, and then threaded the connector screw into the core until the wire was inside the connector recepticle and tight.
That was it.
That was it.
Thanks. I couldn't see well enough into the connector to see any threads.
Did you cut the lead "square" or id you strip some insulation to get bare conductor?
I assume the procedure is to "screw" the connector on to the prepared lead and then reattach to to the dist cap.
thanks in advance.
thanks in advance.
