3.2 Top End rebuild
All cylinders ( 2-7%) except for #1 at 24%!. with the 24% leaking at the base of the cylinder. Best part is that this takes me out of a Watkins Glen DE at peak foliage time. Enough whining.
'86 Carrera has 99K miles. I guess 3.2s do break studs.
Plan is to do complete top end rebuild with race ware studs, top and bottom.
( approx $3500). My mechanic says there should be no need look at the bottom as they last forever.
While everything is out . the plan is to do the 915 rebuild, at least synchros but whatever is necessary.($1300-1800)
I don't want to have to go there again, I drive the car about 6K miles a year and will be eligible for early bird specials next year.
Any other suggestons while we are in there?
Inputs appreciated.
I would suggest the raceware studs, I got some trick stainless ones from Performance Developments as I live 3 blocks from the ocean and studs corode, some 964 cams are a good investment, clean up the intake ports (just clean a little DON"T polish them smooth!) clean up the intake manifold, if you have the extra $500 have the heads machined for twin plugs even if they sit vacant for 2 years untill you get around to finishing it (unlees you bump your compression). you can change compression ratios, lots of options. my botom end in my 3.2 lasted just 181K before the bearing for #5 rod had a retirement party.
Unless you want to short stack your gearing, if your 915 is fine, leave it alone as it only takes a few hours to have the whole thing out again anyway, but if you have a forged flywheel, you can have it lightened and get the aluminum pressure plate and they rev like a crotch rocket!
If budget allows 98mm high c/r p/c used w/ 964 grind cams, twin plug heads, are always nice.
drown some sorrow
