SC distributor/electronic pick up
Can someone give me a way to test whether the electronic pick up in my SC distributor is good. It hits 6000 rpms and it feels like an rev limiter, when replaced by a frineds SC distributor it runs to redline. Any other ideas???
Maybe it is a rev limiter. Different rev limited rotors are available for the SC 6,200 AND 6,800 being two I know of. Ibelieve there is a lower one too. Perhaps you have this. It should be stamped on the rotor. I use a 6,800 one.
RL Technical Advisor
Hi:
Its pretty rare that the magnetic pickup goes bad and when they do, its either a failure to start or ignition misses throughout the rev range.
The first thing I would do is replace the green coaxial cable that plugs into the distributor as thats a common failure point. Then, I'd look VERY closely at the cap and rotor for the minute signs of crossfiring.
If that doesn't cure it, I'd find someone with a distributor machine that can test the whole thing.
