Electrical Problem
4th Gear
Went in for insp sticker...garage replaced rt license plate bulb on 86 911. I later found they had cracked the plastic assembly, and I replaced both sides. Now neither works! Checked fuse, bulbs, both are fine..any help would be appreciated. 33,000 miles
4th Gear
Bill,
Where would I check the ground? The manual said there is a ground somewhere in the rear bumper area? You can probably tell I am somewhat new to this. Thanks for your help
