[911] Targa vent window cap / Corner seal Help
Does anyone have instructions on how to replace this part (http://www.pelicanparts.com/catalog/...athr_pg8.htm#i
tem50)?
I thought it was held on by two screws on the top but there are also two brass rivets that hold it on the bottom too.
I have never messed with rivets. How do you remove and install rivets?
Thanks,
David
1988 911 Targa
tem50)?
Thanks,
David
1988 911 Targa
Gotta pull the seal back and drill'em out, then re rivet them back with a rivet gun head that will fit into the glass channel. Don't know how available brass rivets are, I used stainless.
