911 Forum 1964-1989
Richness
Old Jul 25, 2004 | 10:34 PM
16jake's Avatar
16jake
Default Richness
I recently put on SSI on my 3.0 with a dual exhaust and was told I should richen up my fuel mixture. Any help on how I can do this myself? thanks
jake
Old Jul 26, 2004 | 02:10 AM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Jake:
You should not do this *****-nilly.
You'll need either a 4 or 5 Gas Analyzer, or an A/F meter such as the Innovative ones. Using a long 3mm allen wrench, you can set the idle CO to 2.5% where they run best (open loop).
Old Jul 26, 2004 | 12:26 PM
16jake's Avatar
16jake
sounds like I should take it in. What would a shop charge to do this? would it be worth it for me to buy the meter? thanks
Old Jul 26, 2004 | 07:09 PM
bones's Avatar
bones
Originally Posted by Steve Weiner-Rennsport Systems
Jake:
Steve I've very recently replaced all gaskets and seals, 0-rings etc on the top of the engine without splitting the crankcases and detailed my '78 SC engine, simultaneously I fitted early heat exchangers (not SSIs) and a Triad West Performance 2 in 2out exhaust. The result is my engine no longer hunts from cold start and revs like it is a new engine. I asked my mechanic who installed the engine to check the mixture and I assume he has set it on the rich side if at all. The only downside of my hard work is the engine now splutters into life from a cold start for a few seconds befoire bursting into life where previously the merest hit of the starter fired all cylinders instantly. I think it's mixture related any pointers for me?
Old Jul 27, 2004 | 05:19 PM
bones's Avatar
bones
bump
Old Jul 27, 2004 | 08:45 PM
Bones:
I think you need to check your "cold" control pressures to ensure they are in spec with temperature.,.....
Further, I would see what your idle CO is. 2.0-2.5 is fine.
Old Jul 28, 2004 | 03:59 AM
bones's Avatar
bones
Thanks Steve
