Damage Tach???
Just installed an MSD (6AL), matching coil, and pertronix ignitor. With the Tach attached to the output on the MSD without the adapter, we get a fairly acurate reading. Checked the rpm's with a tach/dwell meter and it is extremely close.
The question is, if we run it without the adapter will it damage the tach?
Thanks!
Jason
'74 911 S
Thanks!
Jason
'74 911 S
I don't know the output signal of the MSD, but when I hooked up my SDS crankfire which has a +80v spike as the tach output and it did fry my early tach. I measured the output of the CD tach output with a scope and it was a large negative spike.
This was on a 914-6, but I think the CD system is the same as a '74
1 Post
Originally Posted by UberScheitzer
Just installed an MSD (6AL),The question is, if we run it without the adapter will it damage the tach?
