ac hose replacement
I'm replacing the a/c hoses in my 930 but am having a bit of difficulty since someone else took the hoses out and i have never seen where they actually go. The brackets holding the hoses under the car seem to dictate rather precisely where the two long hoses are located. However, I'm unsure as to where the two long hoses exit the engine compartment. The one attaching the rear condensor to the front condensor and the one going from the compressor to the evaporator are the ones I'm reerring to. My recollection is that they are simply inserted at the juncture of the rear wall and "floor" of the engine compartment and pushed through until exiting under the car near the left rear shock or right shock accordingly. I can see what looks like a foam tube protruding into the engine compartment at the juncture and disappearing towrd the bottom of the car. Does the left sie hose go int/through it?? i've got the opther hoses routed but these last two have me stumped.
Thanks for your help!!
