Unable to get oil line unconnected!!!
Doing engine drop, where oil line crosses over to other side of engine at that fitting I cannot disconnect. Can I cut this and replace it with new line, or would this be a very pricey part??? Looks like this may have never been disconnected and there is some corrosion on the line could I use heat on this or is there something else that would make it easier to get undone!!!!
I intended to replace an oil line that leads to the oil thermostat. No matter how I tryed, I could not break it lose. A local mechanic told me that more often than not, these nuts need to be split to be removed i.e. using a die grinder down to near the threads in several spots and splitting. Good luck.
Get a helper to counterhold the fixed fitting while you smack the other wrench with your 4lb. baby sledge. Good to be the beater and not the holder. I get a little nervous being the holder! Gotta shock that fitting.
If the fitting can't be loosened with wrenches you will have to cut the nut and replace the line.
Take a Dremel with a fiber wheel cutter and cut it longways, until the male threads just start to show. Then taks a cold chisel and hammer and spread the nut open. After it's spread the nut should spin right off.
Just finished doing the same procedure. One thing I did notice on one of the oil lines was that it was in a bind and therefore was adding addtional force onto the threads.The alignment of the male and female connectors was not totally parallel. I also took a rag, tied it around the connection and soaked with a really good penetrating fluid (Kroil)and kept it wet for several days. It took two large wrenches and alot of effort but they came off and I was able to reuse the fittings when I replace the flexible hose portion.
George Gray
81SC
George Gray
81SC
Well I had to cut it off. One good thing cutting it off only took two minutes!!!Now I only have to undo the cv joints and the four I think mounts and away she goes!!!
