911 Oil Pressure Sensor Replacement
1986 911.
If I replace my oil pressure sensor, how much oil will come out with the sensor?
Is this a job I should delay until the next oil change?
Thanks!
Thanks!
You just have to be really careful, as access is tight if you have AC. You need to remove the oil line and put the brass block in a vise to remove the sender. Even if you can get to the sender with the oil line in-place, the torque you need to apply to remove the sender risks cracking the engine case.
Here is a good thread with links to even more threads: http://forums.pelicanparts.com/porsc...-my-3-2-a.html
Mark
Mark
Thanks for the cranium's up Mark--you likely saved me some unexpected downtime.
After a quick look at it from the top, I thought this was going to be an easy job, but as YOU know there is a bit more to it than simply unscrewing the old sender.
Looks like an off-season job!
Mark
Mark
