1985 911 3.2 Rough cold start
Hi folks -
I recently purchased a 1985 911 Targa and it suffers from a rough cold start issue. I posted a video to youtube to show what happens... on cold start it will flutter between high and low revs. The video I took isn't the worst it will be... sometimes it flutters bad enough to stall the engine. After warming up the car will idle at a consistent, reasonable rev level.
I do believe that the vehicle has a Steve Wong chip installed, but haven't been able to verify that yet.
Any ideas what might be causing this issue? I was considering taking it to a local tuning shop to see if they could diagnose/fix the problem.
Thanks in advance for any help!
Premium Dealer
maybe lean when first started, I would try a smoke test first to make sure that the intake is tightly sealed. There are many other things but but lean when cold would cause it
The following 2 users liked this post by Dr. 914:
arugulamonster (06-20-2024),
silverlock (06-19-2024)
Team Owner
hunting is caused by rich condition. I know many disconnect the o2 sensor altogether.. have you tried a new O2 sensor ? i would ask on Pelican.
Basic Sponsor
Hi folks -
https://www.youtube.com/shorts/9JYOxIVFmHU
Once I've provided a stock chip, the problem was resolved.
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
![](https://rennlist.com/forums/signaturepics/sigpic266260_7.gif)
