911 Forum 1964-1989
Ssi
Old Jun 19, 2004 | 04:13 PM
Deralik's Avatar
Deralik
Default Ssi
I bought a set of SSI heat exchangers for my non-European 80 3.0 SC; thin flange (I think). A friend told me that the heat exchangers I received in a box marked "3.0" from MotorMeister, are for a 74 911 and will not fit my car.
How can I visually determine if they will or will not fit? I don't want to pay for shipping the old ones back AND for shipping the new ones (again) if I don't have to. I don't want to take my car apart to find out. Also, my "friend" at times is right on and sometimes......well, he's my friend what can I say.
Old Jun 19, 2004 | 06:37 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Deralik:
You have no worries, Sir.
There are only two kinds of SSI's: thin flange ones for 2.0-3.0 motors and thick flange ones for 3.2's.
If you are still unsure, take a picture and e-mail me directly,...
Old Jun 21, 2004 | 11:48 AM
Drew Theodore's Avatar
Drew Theodore
The thick flanges also fit some 3.0 911SC's. I think the later models.
Old Jun 21, 2004 | 12:02 PM
emcon5's Avatar
emcon5
These photos were posted in a Thread on Pelican.
You can use thin flange on a car that came with thick flanges, you can either change to shorter studs, or use a spacer of some sort. On my 82 I used a nut slightly larger than the stud.
Tom
Old Jun 21, 2004 | 02:27 PM
RoninLB's Avatar
RoninLB
I installed a thick flange 3.0 set on my 2.7.. It has an o2 bung.
Old Jun 21, 2004 | 03:32 PM
Ron:
Although any version of the SSI's can be fitted to any engine, the thick-flange version with the O2 bung was made specifically for Motronic-equipped motors.
Its all about what length studs one has,....
Old Jun 21, 2004 | 06:06 PM
flatsixcrazy's Avatar
flatsixcrazy
RoninLB,
I have a 78Sc and found a SSI for $250, but it is thick flange. How does one fit the thick flange to earlier SC models. Thanks for your help. Andy
Old Jun 21, 2004 | 06:18 PM
RoninLB's Avatar
RoninLB
Originally posted by Steve Weiner-Rennsport Systems
Ron:
Oh.. I didn't know that.
I was happy to see the bung because I want to install a smog machine using 50/50 glycerine and water for tailgaters.
Old Jun 21, 2004 | 06:27 PM
RoninLB's Avatar
RoninLB
Originally posted by flatsixcrazy
RoninLB,
you'll need longer studs for a good job. you could probably do a partial *** job by using those stud extensions. There seems to be plenty of usable torque with those extensions. I have no experience with them. . removing old exhaust studs could be an issue? if it is a possible few hundred $ expense at a shop then maybe the extensions are cheap and doable.
You gotta research the cost of new long exhaust studs.
Old Jun 21, 2004 | 06:38 PM
Bill Verburg's Avatar
Bill Verburg
You could also swap out all the short studs for long ones.
Old Jun 22, 2004 | 12:16 AM
emcon5's Avatar
emcon5
What year did they change? My 82 is thick flange.
Tom
Old Jun 22, 2004 | 12:33 AM
RoninLB's Avatar
RoninLB
when I spoke to SSI he said it was inconsistant for 2.7, and SC. He never mentioned the 3.2 at all.
Old Jun 22, 2004 | 03:29 AM
randyrap's Avatar
randyrap
ANDY ............. You've got mail!!!
Thanks ............. Randy
