Oil Leak - Thoughts on origin?
Howdy All,
So I have an oil leak that seem to be disseminating from cylinder 3. It runs along the side of the cylinder and down the exhaust manifold. Ends of acculating on exhaust heat shroud then dripping / burning off. It a a pretty good leak too, after drving for an hr or so, if I let the car idle I get a drop on the ground every few minutes.
The upper and lower valve cover gaskets were done recently and no leaks from there. It looks to be coming from the block directly
Any thoughts?
Thanks,Andy
Any thoughts?
Thanks,Andy
