911 Forum 1964-1989
Hard Start When Cold
Old Mar 30, 2024 | 01:01 PM
ahenthus's Avatar
ahenthus
Default Hard Start When Cold
The last three times I've tried to cold start my 87 911 it has involved a long cranking process. It will trip for a second then die immediately. When it does start it will stumble for a few seconds before settling into a fast idle of around 11-1150. During the drive sometimes the idle will stay up around 1100 and other times it will idle around 800. Most of the time it will start normally after sitting during a meal. The ignition control unit and coil was changed a few months ago and that cured a tendency to die and stay off for at least 45 minutes to an hour. After a few months of blissful, no worries driving this starting problem has arisen. It has eventually started each of the last cold starts but has taken a few minutes of cranking and false starts to get it going. Another relatively minor problem the last few drives has been a noise in third gear mostly where when going around 30-35mph it has sounded like the old bicycle trick of using a clothespin to attach a playing card to a fender stay when you were ten years old. The drumming is very muted and mostly noted in third but occasionally in second. Any thoughts on these two problems?
Old Mar 30, 2024 | 05:54 PM
systemsc's Avatar
systemsc
Former Vendor
Maybe the replaced control unit has problems too. Determine the source and warranty of the replaced parts.
7 Porsche Models That Have Aged Like Fine Wine
Slideshow: Some Porsches have become icons with age, proving that great design doesn't follow trends or expiration dates.
By Verdad Gallardo | 2026-06-16 13:40:23
