911 Forum 1964-1989
Battery Drain
Old 02-27-2024, 09:29 AM
Mountaineer84
Mountaineer84's Avatar
The voltage drain on my 86 turned out to be reversed wiring on the engine compartment light. I would have never had discovered this but my mechanic noticed it when it was up on the lift and the light was on. Ever since no issues with battery drain.
Old 03-08-2024, 11:49 AM
ahenthus
ahenthus's Avatar
Any resolution on this? Millermotor, this forum is a valuable resource and would benefit from your findings that would possibly add a dimension to the problem. Hopefully you're not a "one and done" member.
Quick Reply: Battery Drain
