'86 headlights
I have a new to me '86 carrera that the PO outfitted with an LED headlight set up. However the flash high beam seems not to function with this set up. High beams do come on when switch is put into the high beam position. Wiring and fuses are intact and the switch seems to be performing properly.
1) So anyone have a recommendation for high out put lights that retain high beam flash capability?
2) For those that have swapped out their headlights - any recommendation for a solution for the driving lights so that they better match the brighter headlamps.
TIA
TIA
