Help! What was that?
While trying to track down a cold weather/cold start problem (on my 80 3.0L engine enlarged to 3.2 without emission controls) I reached behind the fuel distributor and found an electrical connection with what appears to be a broken wire. What was that? Is it my cold start valve, my auxiliary valve regulator, or is it just some sensor that I no longer need now that the emission controls are gone? Sorry for no picture. It's between the FD and the firewall pad. Thanks.
Paul
Paul
RL Technical Advisor
Hi Paul:
Without knowing the color code of the wire in question or a good picture, its hard to precisely answer your question aside from an educated guess.,....
Does your car start OK from cold?
Does your car run OK otherwise?
Steve,
Thanks for responding. I think what I was referring is the connection behind the mixture control unit that controls the shutoff for the fuel pump in case the car turns over. Apparently this has no other function or can cause no start or run problems.
My only problem is a little bit of popoff valve popping and low idle speed at startup in cold (under 35F) weather. After reading through numerous threads here, I suspect my AAR, AAV and possibly the CSV. I have replaced the WUR which has solved all driveability problems. I have one more area to check: my points, as the car has the original distributor from the original 2.7L. The engine now in the car is a3L, enlarged to 3.2. When I get it figured out, I will repost and let everyone know.
With the much warmer weather we are now having, the car starts and runs like a champ!
Paul
Paul
