911SC clutch noise when released
Hi, can anyone diagnose this issue?
Gearshift in neutral, clutch is up, and I can hear the clutch flywheel engaged (not loud, but definitely hear the flywheels coming together), and the tacho showing 100rpm less than it usually does in neutral. When I push the clutch pedal in, the noise stops and the engine goes back to 1100 where it usually sits when in neutral. Just happened on start up this afternoon after an oil top up. Car is driven weekly on weekends. Haven’t heard this noise before.
No problems with clutch in the past, gear changing has been smooth, clutch has been the same feel for last 2 years (not easy to push down, but not hard). Other SCs I’ve driven seem to have the same clutch feel.
