Brake caliper upgrade, 3" spacing
Hi!
I'm want to upgrade my '74 G model to Boxster calipers. I have difficulties finding an adaptor with the short 3" spacing for the early 911. Anybody did the conversion? Any knowledge of who does the adaptor?
There is a BMW E28 caliper that can be bolted on but not sure why you would
brake torque is a function of
piston area
line pressure
pad co-efficient
effective rotor dimeter
the 911s w/ 3" front brake mounts came w/ M calipers that have the same piston area as the 3.5" mount S and A calipers
they all had 3" mount M rears w/ 38mm pistons until '84 when the front went to the wider A w/ the same 48mm pistons and the rear went to wider M w/ 42mm pistons
S & A all have the same effective rotor dimeters@ 282x20(24 from '84) effective diameter 228mm, an M will have a slightly greater effective diameter on the same rotor so will provide a marginal boost to brake torque at that end
rears are 290x20(24from '84) effective dimeter 244mm
so w/ the same pads the front brake torque is 1391nm @ 70bar line pressure all have the same brake torque result and rear brake torque is 933nm(1183nm from '84)
f/r bias is 1.491 1.220 from '84(necessitating a 33bar p/v on the rear)
the bigger front A & S pads compared to a front M actually reduce brake torque by a small amount due to the larger effective diameter, they mostly increase brake pad life
the thicker rotors used from '84 only increase the thermal capacity of the system and have no effect on brake torque
The most usual complaint wrt 911 brakes on track is heat issues, the fronts in particular can get very hot, boil the brake fluid w/ resulting long/soft pedal, no fun!!
solutions
loose as much weight from the car as you can
learn not to use the brakes so much
use only fresh(the newer the better) highest quality brake fluid, Castrol SRF is the best that I know of though there are a few others that have higher dry boiling points, they all fall behind in time
add deflectors to the A arm to shoot extra air to the calipers and rotors, ducts are almost always way too small to do any good
use pads pads that have higher Mu at higher temps
Listen to Bill's advice ... he knows 911 brakes !
Your best bet is to use top quality brake fluid and get some sort of cooling ducts for the front brakes.
I DE'd my 89 911 in the black PCA run group with stock 911 brakes for a few years before i changed the brake system completely , but the stock brakes were just fine.
Cheers
Phil
Cheers
Phil
If you are bent on replacing the front calipers, I have a spare set of beautiful Brembos with 3” ears. Bolt on. Text me if interested.
cheers
cheers
well a caliper change is only a partial solution and then only if the the caliper piston areas are larger than the stock S/M/A 48mm ones
piston area
line pressure
pad co-efficient
solutions
piston area
line pressure
pad co-efficient
solutions
