1978 911SC Front side marker euro delete install?
7th Gear
Morning guys - I am stumped - Can you help? I purchased the pair of Front bumper side marker euro delete parts, for the euro style from Pelican --- See 3 photos attached..
I thought I just remove the lense, then the bulb (tape off wires) and install... however i dont see how these rubber blocks fit in?
Do i have to also remove the inside lenses housing? And if so, how?
Any help ASAP greatly appreciated! Thanks, Jon
Team Owner
not sure why you would even want to do that
Most guys are proud they have a euro model and kinda want to show it off.. i would .. something different .
JONGIB627 (02-24-2022)
7th Gear
Aaaaaah sounds good!! I see how now - Got it from the Bellows! 4x 8mm nuts from the inside the wheel well with with the wheel off, then remove the 2x 8mm nuts that hold the housing on - Thank you guys :-)
