Help me identify these parts
I just bought an 84 Targa, and it came with a bag of miscellaneous parts, please help me identify these parts and where they go. Thanks for your help!!!
6 is a plastic washer of some sort
7 is an EP rom...maybe a DME chip?
8 is some kind of plastic in a tube shape with holes in the side
9 looks like it could be a seat belt anchor cover
I think 5 is the plastic piece that slips over a metal coat hook. There should be one on each B-pillar. The little black washer (#6) might be part of the seat belt assembly. There are black plastic washers for the pivoting seat belt hardware where it bolts to the body. The chip (#7) may be the factory DME chip - you may have an aftermarket chip in there now like a Steve Wong.
Number 4 looks like a pivot for a sun visor.
Mark
Mark
Parts 1, 2, and 3 are parts of the seat belt mounting caps – plastic pieces that cover the metal seat belt bracket above your shoulder. 1 and 3 together form a pair. 1 is the top portion of the mounting cap with a plastic piece broken off. 3 is the bottom half. When 3 is turned 180 degrees, it will snap into the bottom of 1. 2 is part of a second cap. Here are some links to show what 1 should be.
https://www.suncoastparts.com/product/92880314100.html
https://www.stoddard.com/92880314100.html.html
ErrorMargin (01-21-2022)
