What is it?
Under the hood, there is a opening that is slighlty to the right of center (passenger side, toward the dashboard of the car. When I open cover that is on hinges to look inside there is a large black plastic thing that I am not quite sure what it is. There are some wires that go to it. It looks like some type of blower motor. What is it, and when I reconnect the battery I hear a click coming from that area. Should there be a click when the battery is reconnected? I am trying to find a short and wondering if this could have something to do with it.
Thanks.
Thanks.
Fan motor system/thermostat for the AC system. Your car does have AC? This is controlled by a switch on the dash, so if the switch is on then you would hear it and feel the air blowing in the cabin. I removed my AC system, but retained this assembly and use it for fresh air. Good luck.
Do you know if that should click when I connect the battery back up? Something is going on at connection. I can hear a noise and feel the ping as it happens if I put my hand on the plastic blower housing that is exposed. So something is going on in there I am just not sure if it should and I do not have my wiring diagram handy at the moment. I did have ac, I removed the ac motor and bracket in the engine compartment and the coil thingy that use to hang from the engine lid. Do you know if the a/c should able to turn on without the key turned to an off position?
Thanks for your help. Beautiful car by the way, checked out your website.
