air pouring in through dash speaker
I have a tremendous amount of air coming in through my dashboard speaker on my 69e. Any thoughts on how?? My trunk is down and everything behind the board that conceals everything under the dash looks correct. ???
It is more complicated than just that. In a 1969 911 there should be at least three physical barriers between you and outside air via the dashboard speaker. Air from the outside into the trunk. Air from the trunk through the trunk compartment liner. Air from inside the trunk compartment liner through the speaker itself. That is assuming you don't have a giant hole in the floorboard somewhere.
