1983 911SC chassis fuel line recommendations
Greetings. Finally getting this 83'sc up into running shape. While replacing the fuel pump, the high pressure fuel line basically came apart, and the plastic fuel line
going from the high pressure line to the chassis appears to be kaput as well.
We will be pulling the motor/trans and just redoing the entire fuel lines, as the car is almost 40 years old and has sat outside the past 10+ years.
Is anyone making a kit or do we have to replace with the factory plastic lines? Anyone have any advice?
Thank you! I can post pictures here shortly.
Len Cummings on Pelican makes a great kit that many of us have used. Email him at Len dot Cummings at verizon dot net.
Do a search there for fuel line replacement and you’ll find a bunch of threads.
Mark
Mark
