Confirming carrera tensioner upgrade?
Is there an easy visual way to confirm if my 911 sc targa has had its tensioners upgraded? Does the presence on oil lines running through the chain cover housing mean yes?
Thanks, Graham
Thanks, Graham
Technical Specialist
Lifetime Member
Lifetime Member
Graham,
If you see an oil line running from each chain housing cover up to the cam oil lines, then the tensioner upgrade has been installed.
What Bill said. You can see pictures of the lines in the Pelican tech article: http://www.pelicanparts.com/techarti...ensioners2.htm
Tom
Tom
