Carrera 3.2 Air filter box clipz
Hi,
I'm trying to get access to my air flow sensor.
In order to get access to it, I had to remove the airbox, so i took the clips off the front and the whole. With a little bit of wiggling I managed to pull out half the box along with the air filter.
I now need to put it back together, however it seems virtually impossible to get the rear 2 clips fastened. Is there a method to reinstalling it?
Kind Regards,
Ash
Kind Regards,
Ash
One thing you might consider is opening up the airbox by removing the snorkel and cutting out the face around the air filter. It gives you a bit more intake noise at WOT and some say it might make a bit more power if you've got a chip and/or sport exhaust. I have both those and don't feel any performance gains, but no negatives either and it does sound a bit better to me. The biggest improvement is that it's about 100% easier to change the air filter without destroying your hands; now very easy to get to the rear clips. I did get stuck in some fairly heavy rain and didn't have any issues with the filter getting wet.
Hi,
Kind Regards,
Ash
Kind Regards,
Ash
ninjaRS (04-29-2021)
The car is based in Malaysia, we get monsoon rains here. So we'd probably try to keep the airbox stock. Don't have any performance parts on the car, it is as stock as it gets.
The car didn't come with a cat or O2 sensor.
Still trying to figure out how this installation is done with the stock box. My palms and forearms definitely will not fit
I don't remember details, but it is definitely a little tricky, and is definitely possible without mods or cutting anything. I don't think there is a secret that makes it easy. Just keep thinking and trying different things is what I'd do.
ninjaRS (04-30-2021)
In my 86 carrera I can reach the top back clip by reaching over the engine and in back of the filter housing. For the bottom one as I recall, it helps to remove the oil filler cap and reach back along the side of the engine- but it is TIGHT
I had a little luck without the filter installed to get the rear. But my forearms were too large so I had to ask my skinny neighbor with his thin arms he was able to reach under and get them without issues. Having the Mrs. Is a good idea.
CTopher
CTopher
I have the same problem with my 1987 Carrera. Last time around my teenage son was able to get his hand back in there to flip that clip. He has since grown and filled out so I will have to find another thin armed and long fingered person to help next time around.
Good luck.
Good luck.
First tip:
To help find that handle–as well as provide some extra leverage–attach a zip-tie to the latches. Don’t worry, you won’t lose any concours points because no one will see them because we’re only talking about two latches on the backside of the air box. More on the why in a sec.
Second tip:
In order to reach those two toggle latches on the backside of the air box, you need to get your arm all the way back in there–between the air box itself and an a/c line. If your arm seems to get to a certain point and then just gets stuck, lube up your forearm with some petroleum jelly.
Your lubed-up forearm should easily slip back behind the air box, and now your fingers can fish around for that zip-tie.
The zip-tie likely will have slipped out of position, but you should be able to finesse it back into place so that it can articulate the latch. Pulling the zip-tie should then snap the toggle latch into the closed position–yes, you can pull on the handle itself, but the zip-tie provides a bit more leverage.
Now enjoy your extra-soft skin the rest of the day.
Second tip:
Hi,
Kind Regards,
Ash
Kind Regards,
Ash
As for the rear lower clip, I only found it possible by using my left hand, palm facing inward and thumb down. But yes, it is possible without modification..
how do you get these back on? long skinny arms :-)
I agree with removing of the snorkel. Was not able to do this either with the snorkel attached to the airbox right part but with that part disconnected,
found out that with a screwdriver, it is possible to detach the snorkel, install the airbox housing, fasten clips correctly, and then "turn" in the snorkel again
never worked without removing the snorkel...now it's still tight but doable
