Rear brake caliper piston frozen
79 911 SC. One of the two pistons on my driver side rear is completely frozen in the caliper. The other is half way out and clamped to hold pressure. I’ve soaked the stuck piston in PB Blaster overnight and applied heat to the caliper body as well. Using the setup below, I applied 120 psi and get no movement. Any other suggestions before I buy another caliper?
If I have to buy another should I just buy a rebuilt unit? It’s a quarter the price of a new one.
Team Owner
sounds like its jammed... i would get the special tool for pushing it back in first ... or a good quality C clamp... the tolerances are very tight and if its **** eyed it likely has to go back in before it can come out...
i ran into this exact issue when rebuilding mine..
I can’t imagine working on a 4 or 6 piston caliper.
The brake fluid was old, too old. I’ve flushed the front brakes within the last two years but not the rears. I’m going to flush all four during this exercise. I built a power flusher a few years ago using a garden sprayer with fittings and a hose. I secure it to the reservoir overflow and I’m able to sit at the wheels and flush/bleed them alone. Works great. As backup I always throw a blanket over the reservoir in case the hose comes loose. It shouldn’t because I use a clamp but better to be safe.
I use that same setup, but don't put any brake fluid in the sprayer.
This is a good time to replace all the rubber brake hoses with new from the dealer. (not to mention any old rubber fuel hoses)...
Congrats on getting the piston out and finding no rust!
Fitting
Fitting in caliper
