Best upgrade for the money?
#32
I doubt I could drive a stock 911 to it's full capacity, but I had to freshen up my suspension to prepare it for the track. I figured the while I had everything apart, I may as well upgrade everthing I can within reason. I will be attending all the track events I can after my car is finished in two weeks. I will be able to take it to the track fully confiedent that the car has been completely gone through & prepared to the best of my ability.
#33
Originally posted by Petevb
Yes, those shifters are that much better.
The wevo is much more precise and rigid. If I push the stick side to side while in gear there is virtually zero free play. Much easier to shift, much better feel. I improved the shifting of my 915 twice- first, I did the wevo shifter, then I did a full rebuild plus an internal wevo gateshift. I'd say the improvement I got from the shifter alone was almost equal to the other two improvements put together, but you can imagine how much less the shifter cost...
